1 - 2 of 2 Posts
I bought Techstream and a cable off Amazon that was suggested by someone on this forum. But All I can seem to get is some basic info like with a $20 walmart code scanner. I try and go into "configuration" and it won't let me in. I was hoping I could change some things about the way the car works like disabling the sound when the power door locks are used. Can someone point me to a resource on using Techstream. And are there any advantages to going to a higher version than 12 for my 2007 RAV4?
Here are some of what I've gotten out of the program so far:
Techstream (Ver 12.20.024) - 10581
Vehicle Configuration (S323-01)
Please input Vehicle Configuration code.
Vehicle Configuration function is disabled if inputting a wrong code 10 times in a row.
Line inspection/Cable check result:
1,2,3,6,7 are green
4,5 are red
Communication Bus Check
Only result showing is "Certification (Smart) is in red which means "No longer communicating on the CAN BUS.
You can try Customize Setting if you just want to change something, such as turn signal, how long light should stay on after engine turn off...
The function is very limited for such versions.
1 - 2 of 2 Posts
