I've done some digging, and most of the time it is the rear swaybar links. I've had to replace those a couple times in the past, but this is a totally different noise. I've checked the links and they are fine. This is a clunk that happens when going of particular kinds of bumps. Like, it won't do it if I go over a speed bump, but it will do it in a parking lot with uneven pavement. It just has the sound of something just swinging and thunking against something hollow. I've lifted it up on both sides and crawled around under it trying to find what could be clunking. The wheels are solid. No strange wear patterns in the tires or anything. Toe and camber seem to be correct. The wheels aren't moving when you try and shake them. Suspension seems solid. I'm just trying to think of what could be loose down there that would thunk around and not throw off the handling of the car. It almost sounds like something rolling around in your trunk. I've checked any open space that could have something loose in it and have literally come up empty. Any thoughts before I finally break down and take it to a shop and pay money to get this noise found?
