1 - 20 of 28 Posts
So at 199k miles I burn exactly half a quart for every 1500 miles (This is with the assumption that the dipstick lowest and highest marks are one quart).
... so ONE quart every 3000 miles. ...
Most of the first gens I have seen are around 200k or close by.
What is your oil consumption like?
I would be really interested to find somebody whose first gen is not burning any oil and it is at 200k.
also..
I use 10W30 Pennzoil high miles... what do you all use and why?
Also what is the oil change interval. I change every 5000. Of course I have to add oil once in the middle.
Do some of you keep on just adding oil and never change oil? LOL
Hey RAV4EVR! Im in the same exact place that LugNut is in. 101K miles and no oil burned. Have you checked your PCV valve to see its condition and if its dirty or not? Hope this helps!
Anthony
Anthony
PCV valve has been changed. Made no difference.
The RAV does smoke at start up only.
The smoke is visible only, apparently, at start up, but you're still pulling oil through the seals. Check your plugs for fouling.
Hopefully your rings are OK. Do a compression test though.
If compression is OK, see the threads here (including mine) about changing the seals -- a big job.
Discussion Starter #7
Yes. I will get those seals done also in the next year or so. My deal is that I don't want to do it and then figure out that I needed a new engine anyway.
Would it not be better to just change the engine?
With this thread I just want to get a feeling of what other people with about 200k miles are experiencing with their engine.
IMHO, unless you've thrown a rod or worse, it's always better to rebuild than replace. If you have a good machine shop nearby and can do all the mechanic's work yourself (including disassembly, parts cleaning, and reassembly), it's generally not that expensive a project (buy quality parts on-line, e.g., a Fel-Pro gasket kit, etc. from RockAuto.com). Having a good, experienced mechanic-friend to teach/help you, and a factory service manual, are very valuable in the process if you never rebuilt engines before. Patience, space, and good tools too.
But if your compression numbers come back great, I'd just do the valve stem seals and any needed externals, e.g., timing belt, water pump, plugs, ... You can reuse most everything except the gaskets if you eventually decide to do a full rebuild.
Discussion Starter #9
I have the following I picked out from the forum. Anybody has had this done at a shop? How much should it cost? After compression testing I might go for it but I don't think I am loosing my oil because of this. I think it is 200k miles. LOL... So there is nobody with around 200k miles with this issue of loosing half a quart every 1500 miles?
Its valve guide seals, a known issue.
Its expensive to replace them as the cams have to come out, so just ignore it, it does not cause problems.
After you shut the motor off, the oil works its way down the valve guides over time, the longer the time, the more smoke you get.
Its not a lot of oil.
Its part of the design, buckets and shims above the valves, and most engines of the same design do it when the seals wear out.
also..
Happy to say, my RAV4.1 doesn't burn ANY oil. It goes from oil change to oil change without burning ANY oil at all. Oh, BTW, it has an oil and trans-axle coolers. It's very simple to install. The trans-axle was the easiest. My RAV4.1 is 2WD. The AWD came with a small cooler for the AWD system. Mine came with just an invested "U". I just cut the "U" and left about three inches of aluminum pipe. Sending the Derale Hoses to the radiator. The rest was just adding the supplied sandwich aluminum block and sending the hose as you can see. Metal Hoses would be a nice upgrade.
I'm unhappy to say mine uses loads of oil at 230000 miles. It's been overheated around 50 times since I've owned it and about 18 months. I top it up so often that it really doesn't need oil changes. Be happy about the amount you are using. It's under what toyota worry about for a new car. That is a fairly light oil you are running. Is it particularly cold where you are?
Discussion Starter #12
How many miles do you have? Original engine?
Discussion Starter #13
I just wanted to get an idea of my engine condition at 200k miles and other RAV4s at around 200k with original engines.
It is not cold. 60 to 80 degrees these days.
On the contrary, its hot, all year round. On the 25 of December we are doing 80 degrees. I use the il recommended by Toyota, 5W-30.
Discussion Starter #16
A little over 100K miles. It runs very well, but I also change the oil ever 3k to 5k miles, religiously.
Well. I assume that at 100k it would be like that. These are good engines. If I am burning half quart every 1500 miles at 200k then it must have been like yours at 100k. Just assuming.
Sadly I can't get any numbers from the 200k people which is where I am at.
Most people who have this generation RAV4 are probably not even on this forum. I see them pretty banged up and driving around without any care or passion.
I guess we are "weird".
Same here, I see many chugging along after all these years. Same as in this forum. I've seen people come and go since 1996 that I logged on. :D Yes I have other cars. But I still use my RAV4.1 religiously, and it's still running like a jewel.
This morning I got up at 4AM. Tomorrow is students day and we are having some activities with the students. I went to my local SAMS to get some junk food. It was a cool morning and not a soul in sight. I had a blast driving in the cool dark morning. It was great. All the time thinking; "Damn, after all these years, she still runs great".
Discussion Starter #18
Exact same feeling when I drive it.
When we go out as family I force everybody in my 18 year old RAV4. I don't want to drive the Sequoia or the Lexus.
According to my friends I am putting my family at risk for taking them out on a "not so safe" car as compared to others in my garage.
I just love driving it. :D
also..
At 155k mine was using similar to yours. 10-40 wt and a qt of Lucas helped. Changed oil every 3k and still do. I would've lived with it except that puff of smoke was driving me crazy. Did a wet/dry compression test, determined it needed a valve job (well, valve seals to be exact, but I opted for a complete valve job). Now at 162k eating no oil and no more puff of smoke in the morning. Better, smoother performance especially on long trips. It was worth the money.
Discussion Starter #20
Oil level stays same now after the valve job?
How much did it cost if you don't mind me asking?
1 - 20 of 28 Posts
