There are a few significant differences between USA and Canadian, also year to year, even with same engine.
Toyota changed its tune and stretched out the maintenance intervals, maybe starting with that 2012 Canadian manual you posted. In 2009, the spec for oil change in the 2.5l 4-cyl is 6 months/5K miles. Now it is 12months/10K essentially same engine in the 2013+ RAVs.
This tells me once warranty is done, I can go to the extended service if I choose to go synth.
Another big difference, the Canadian service schedule is more aggressive on frequency of other fluids, at least for my 2009. For example, they specify changing transaxle/front diff fluid at 6 years/60K miles for
all models. Of course, you have to convert the km to miles, see pages 23-24:
http://mediapv4.toyota.ca.s3.amazonaws.com/media/pdf/09manual_e.pdf
Maybe more frequent because Canadian weather is more harsh in general than USA? Anyway, as AVS noted, you can look at all these Maintenance Schedules--and other than maintaining the warranty, cherry pick the ones that are right for you. I've pretty much adopted the Canadian 2009 schedule on all my fluids, as weather in Idaho probably as harsh as Canada, eh! And will stretch the interval for oil change after warranty expires as well, cause RTexasF said it was okay!
