The first oil change is due at 10,000 miles (16,000 km)
They're trying to tell you that it's due at 10,000 miles, not 1100.Speaking of oil filters... I have a 2022 Rav4 XLE Hybrid with about 1100 miles on it. Now that the car is past its break in period I want to change the oil and filter, but I CAN'T GET THE FILTER OFF! I have used 3 different oil filter wrenches to no avail. Is this Toyota's way of making get our filters changed at the dealership? Suggestions?
I use this cap wrench with a microfiber towel between the wrench and the oil filter for added grip and friction: Robot or human?Speaking of oil filters... I have a 2022 Rav4 XLE Hybrid with about 1100 miles on it. Now that the car is past its break in period I want to change the oil and filter, but I CAN'T GET THE FILTER OFF! I have used 3 different oil filter wrenches to no avail. Is this Toyota's way of making get our filters changed at the dealership? Suggestions?
Just keep trying, or stick a big screwdriver through it.Speaking of oil filters... I have a 2022 Rav4 XLE Hybrid with about 1100 miles on it. Now that the car is past its break in period I want to change the oil and filter, but I CAN'T GET THE FILTER OFF! I have used 3 different oil filter wrenches to no avail. Is this Toyota's way of making get our filters changed at the dealership? Suggestions?
Take note that he is using a towel as a spacer between the filter and an oversized filter wrench.Bazinger,
I just measured my spare oil filter, 90915-YZZN1. The end of the filter measures 64 MM, with a digital micrometer. . Yet your link above is for 74-76 MM size wrench? Is that the correct link?
Bazinger,
Negative, almost everybody here has a tight filter -and I don't believe the filters are installed by hand in the factory. Maybe they are.I just did my first oil change tonight. My dealer sold me 90915-yzzf1 which is the longer filter. It fits fine and should be easier to get off than the shorter version. The original filter was put on by a gorilla but I got it off using the cap style filter wrench with relative ease.
FWIW I am doing my first two oil change intervals well before the 10K mile recommendation too. I always have dropped the first oil change early and never had any engine oil or oil consumption issues with any of my cars.
Using the right filter wrench makes it super easy. Doesn't matter how tight it is. I have 3 or 4 aftermarket cap wrenches of that size and none of them work right. I have just held onto them for whatever reason.Speaking of oil filters... I have a 2022 Rav4 XLE Hybrid with about 1100 miles on it. Now that the car is past its break in period I want to change the oil and filter, but I CAN'T GET THE FILTER OFF! I have used 3 different oil filter wrenches to no avail. Is this Toyota's way of making get our filters changed at the dealership? Suggestions?
Tightened by a gorilla is an expression. No, it wasn't odd that it was that tight. I used to work at a car dealership in service and as I recall all factory installed filters were extra tight compared to cars that had oil changes done by people. It's rare that I can't get a filter off by hand.Negative, almost everybody here has a tight filter -and I don't believe the filters are installed by hand in the factory. Maybe they are.
Did it not strike you as odd to tighten it as much as it is? It can't be expected to be an easy removal in 6 months with as tight as Toyota thinks the filter should be.
Yes, I know it was an expression.Tightened by a gorilla is an expression. No, it wasn't odd that it was that tight. I used to work at a car dealership in service and as I recall all factory installed filters were extra tight compared to cars that had oil changes done by people. It's rare that I can't get a filter off by hand.
