Hi
I have this problem. Without the key inside..the dash show the light for oil and check engine on and from the engine a heard a noise..like coming from the ordinator. During the night I imagine the battery was finished and I could start in morning time. After I busted an the engine runs the both light stops...but when I stop the car they show again. The level for oil is correct...and I changed to be sure is not coming from there...inclusive the filter. When I run no lights show on the bord. Only when I stop...the light for oil and check engine come on.
Somebody has same problem?
Thanks.
Sounds like there's a problem with your ignition switch and it is not shutting off fully to the off position.
All dash lights except headlight/highbeam and the door ajar indicators should go out when the key is shut off.
CEL and Oil will always be on when the key is on and the engine is not running.
