can you post a picture of the entire engine bay? Also give us a run down on parts and cost.
Here you can find the pic of the engine bay : https://www.dropbox.com/s/an6w0iy1p87l1rh/oilcatchtank9.jpg?dl=0
And also here in my garage : http://www.rav4world.com/forums/mem...uild-1998-6593-picture40290-oilcatchtank9.jpg
The Cost for me are zero because i do everything myself and always with bits and parts that i have lying around .
The oil catch tank i made from the fuel tank com's of a Zibro Kamin heater it has a litle window in it so you can see when its full and i made baffles in it with steelwool filters .
the pipes are steel wrapped high pressure water pipes .
I have 2 tubes coming from the cylinder head cover with a tee to the inlet of the catch tank .
And then, the 1 tube of the outlet of the oil catch tank to the original position behind the air filter.
The oil catch tank has a stop at the bottom that you can press to drain the excess oil and water.
I must say after removing almost all vacuum and the egr valve and placing this oil cath tank the engine runs much faster and sounds like a small racing car its nice the sound not annoying.
