yeap, that's red primer and then flatblack paintDerek said:Wow... sun did a lot of fading to that fender flare.Nice outcome though, I'm guessing the red one in the middle is primer.
I might have to do that to my plastic side cladding soon, because the hot Hawaiian sun is slowly fading my cladding and bumpers.![]()
in the first pic I use sandpaper #220 and after the red primer I use a 320 to erase the hole that it had and after the 320 I use grey primer (it's like rubber(goma) for a better resistancemensajero said:Did you use sandpaper in the first picture. If so, what grad? I guess the primer was with a paint gun. I doubt that is spray from a can, right
Translation :idea:
En el primer retrato checho, que # de lija usaste? El primer, fue pintada con pistola o con esprey?
I paint it with engine paint (sprey)mensajero said:Did you use sandpaper in the first picture. If so, what grad? I guess the primer was with a paint gun. I doubt that is spray from a can, right
Translation :idea:
