Did the oil level as measured on the dipstick go down after your wife had driven the 250 miles, or is it the same? Or was the level even measured just after the new oil had been added and the engine started to test for leaks? If there was no apparent problem after your wife had driven that distance it is likely that there won't be one.
But I'm a fussbudget about such things. Once I overfilled the small block 327 Chev. V8 in my pickup truck and when I discovered that I had done that, I drained the excess. A bit of a messy job, but I felt much better afterwards!
