Do you have the MyT app? That's your proof from the trip recordings that you are in fact driving it enough.On 18 Feb 2021 we took delivery of a 2021 Toyota RAV4 Prime Plug-in-hybrid from Westcoast Toyota in Pitt Meadows BC . The vehicle has performed flawlessly, with one major exception.
One of the reasons for selecting the RAV4 was Toyota’s reputation for reliability and relevant experience with hybrids. Reliability is very important to us as the vehicle travels on forest access roads well beyond cell phone service which means a long walk to help. Even within cell coverage or via Toyota Roadside Assist, help for a dead vehicle is hours away, probably not until the next day.
On two occasions the 12 volt battery of the RAV 4 PHEV has died overnight. After prompting, the dealer checked that “the system has the latest software in accordance with Service Bulletin. “T-TCI-5389 DCM Reset and Firmware Update (LG)”. The dealer staff, on both occasions of failure, accused us of “not driving enough” yet did not even ask if the vehicle had been driven the day prior or if it was plugged in overnight (yes to both). Attempts at further discussion made it clear that the dealer staff have no interest whatever in finding a solution.
A request to Toyota Service produced another legalistic evasion and a request that we deal through the dealer. So, we have asked the dealer:
1. To remain operational, must the RAV4 be driven a minimum distance per trip/day?
2. Must it be driven in HV mode?
3. How many days can the RAV 4 remain inactive then reliably start?
4. If/when the 12 volt battery discharges again, what would you like us to do:
No answer yet to these questions. So, the present situation is that we have a Toyota RAV 4 PHEV which has its reliability compromised by an unknown defect which is aggravated by a Toyota dealer with no interest in finding a fix.
In the hope of helping find a fix, I am maintaining a log of voltage of the 12 volt battery at the start and end of each driving day. When the RAV4 PHEV is in the garage a 1.5 amp battery maintainer is connected to the 12 volt battery and the key fob is disabled.
Has any RAV 4 owner found a fix for overnight discharge 12 volt battery.
Ron
My understanding is that the 12V battery charges off the traction battery so all you need to do is actually switch the car on and it is charging from that point onwards. The UK forums suggest that you just need to have the car 'on' or drive it in any mode fir about 20 minutes a week to maintain a good charge on the 12V battery.
From own experience I've left the car several times for 2 weeks or more and not had an issue with starting. Car is outside in the wet, ice, snow.
Sounds like your dealer is just a c***. Our dealer bends over backwards for us over here in the UK. You could have a fault somewhere like a short or poor earth bonding. Basically they need to put an ampmeter in series from the 12V battery to determine current draw when the car is off and supply when it is on, then compare these amp values with what it should be. They should also check via resistance measurement all of the earth bonds. This is the absolute minimum they should be doing, or they are the baby of two village idiots from two seperate villages that met one night.
Sent from my SM-N950F using Tapatalk
