If you have a .25 amp draw, it will drain the battery of 6 amps per day. If your battery was dead one day and just got a boost to get it started, it has to be recharged to be back to its 60-65 amp capacity, just driving it for a few kms will not recharge it and it will be recharged only to 10-15-20 amps capacity , the 6 amp draw per day will be enough to bring it back at a too low state of charge to start the car. dont forget that a lead acid battery looses about 50% of its power at 0 degrees.
You need a miliamp meter to check the drain, you have to open the hood,lock the car , wait a few minutes and then plug in the miliamp test meter in series with the neg battery post without loosing the circuit. that means plugging one wire of the meter to the car negative cable and the other wire of the test meter to the battery post and removing the car cable from the battery post without breaking the circuit, you will get the reading of the power drain.
