21 - 23 of 23 Posts
Thank you every one,
Below is the outcome.
When scoped the cam sensor would go below the voltage threshold in red when going around left bend,
Normally the voltage at idle would be 1.5v (3v peak to peak)
Took the rocker cover off and found the camshaft broken.
149219
149220
Told you. I been a toyota mechanic for 30 yrs. It's a fault that I have struck a few times. The voltage drops down when the camshaft travels away from the camshaft senor when turning only left.
Very impressive diagnosis and fix gents. Probably above the pay grade of most Toyota dealers and mechanics.
I moved this to the more appropriate thread - Mechanical.
21 - 23 of 23 Posts
