Hey ladies and gents, I'm looking for some info on how to reset the computer on my 2020 Rav 4. I replaced the rear pads and rotors on the vehicle and it was my first time working with an electronic parking brake; I disabled the electronic parking brake to remove the old pads and rotors and upon attempting to reinstall the new ones noticed that the piston does not push back as I'm used to, and a clamp could not be used to compress the piston due to the electronic motor on the caliper. I looked it up and the vehicle had to be in brake maintenance mode so I attempted to do so - 3 pulls up, 3 presses and hold down on the parking brake switch. The caliper then decided to apply the parking brake and at the time the pads were not installed so there was nothing for the piston to push on therefore the piston was pushed out of the caliper. Finding no solution online I removed the electric motor by taking out the two hex screws, used a T-45 to wind the caliper back and then manually pushed the piston all the way back. I then reinstalled the electric motor and brakes and bled the system.
The brakes work great, no issues whatsoever but I cannot get the "parking brake unavailable - visit dealer" message to reset, I've tried a maintenance reset on the dash, I've also tried unplugging the battery for 5mins and I've tried going for a drive to see if it picks up that its been wound back. I'm wondering whether or not the electric motor is now mismatched on its position with the caliper (I doubt its that complicated, I would assume the sensor picks up pressure in the line but you never know) or if its as simple as a system reset on a scan tool.
I'm hesitant to bring it to a dealership because I doubt they would let me speak to a tech to explain the situation and will most likely try to install new calipers instead and I hear they are nowhere near cheap.
Hopefully there are some suggestions. Thanks.
