1 - 20 of 25 Posts
S
Check out my album for PICS of my XM radio install. I ended up using a bracket from PANAVISE to mount it on. I had it installed using the Wirless FM Modulator that is built in the radio, which would not do in my old Titan, but it sounds great going through the JBL :D I had to hard wire through my AUX in the Titan, thus rendereing my AUX useless for other things. The one picture also shows the Homelink mirror I installed :D
Did you screw/stick/velcro the mount onto the dashboard, or did you find a seam to wedge it into? I'm trying to find a way to mount my cell phone and PDA and it's not gonna be as convenient as the 4.2...
(With my '01, I used one of the screw points on the center console face to mount a thin metal strap -- was very surprised to find out they weren't fake!)
S
The PANAVISE Mount wedges in the seam between the brushed metal colored plastic and the dark dash. Here is the part # 75137-806. The radio mount just screws into the PANAVISE mount. Pretty seemless and no wires hanging around :D
aww man, you beat me to it! Where did you but it from? I knew it was out but haven't found a place to get it. eBay doesn't have it yet, which is where I got my last two Panavise mounts.
Canyon River Cellular Company shows it for $20.86... Shipping for me amounted to $7.85, YMMV... The only other Google entry that listed the part number (other than Panavise) wanted $27.99 + $6.90 shipping.
Pretty pricey for a bit of bent sheet metal... :?
S
Discussion Starter #9
kestrel55 said:
cool. How is the unit powered?
It is hardwired behind the dash. I am assuming into a 12 volt lead somewhere. I had an installer do it. He did not have the PANAVISE in the store but has a supplier in town. He just drove over and picked it up while the installer was running the wire :D
S
Discussion Starter #10
I paid $24.99, but the guy was able to get it local, no need for shipping :D
S
Discussion Starter #11
I had Stereo King in Portland do the install, he went somewhere in town to a supplier to get the Panavise, don't know where. You could call Stereo King and get his supplier though. Stereo King has a website on the net :D
Thanks sstarrx3 this mount will be perfect for my Garmin Quest.
I did not understand the instructions before it finally dawned on me that "remove the cover that includes the wheel lock switch" meant the LSD/4WD lock switch.
I removed the panel by placing some blue masking tape below the cover to avoid scratching the bottom panel and then sliding a thin pocket all-metal ruler under the panel. Using a paint can top remover I gently pried up and it come out easy as can be. It sort of eased out instead in snapping out. The top part was a little harder but it came loose with a little more prying near the top. The switch comes out with the panel but has a wire attached to it with a connector.
I just order the mounting from Canyon River and I will post pictures when I get it installed.
Canyon River's on backorder and won't get the brackets in until 4/29... *sigh!* :?
B
Discussion Starter #14
Sstarx - where did you mount the satellite antenna and how is the cable run to the unit?
Cheers,
G.
S
Discussion Starter #15
Cheers,
G.
The antenna is mounted at the rear of the car in the center. The cable comes out around the weather strpping in the door. I did not mount it so I am not sure. I imagine it runs overhead under the skirt , making its way down behind the dash.
I cancelled my order with Canyon River because they were out of stock as noted above and ordered from a local representative. It came in 2 days but cost full retail.
S
Discussion Starter #18
I can't tell any difference between it and the OEM antenna. I have to admit that I don't listen to FM radio much since I have XM. :D
Anybody done a Sirius install? I have a Starmate Replay (pnp) that I want to hard wire and permanently install. I currently have the suction cup mount that I would love to get rid of. Additionally, I would like to run the output through the aux. for greater audio clarity.
I was thinking the sunglass holder in the headliner might be a good place to install? Anybody tried to install here? Any thoughts would be appreciated.
Thanks.
My Panavise mount from Canyon River showed up today -- looks like they got them sooner than expected! :D
1 - 20 of 25 Posts
