441 - 460 of 610 Posts
what kind of mpg increase are you getting?
While the handling is much better I have not seen much difference in the gas mileage. This is surprising since adding larger wheels and tires makes a big difference in lowering the MPG. I can't figure it out but will keep monitoring it.
Anyone have prices for Black Lug Nuts?
I don’t want the wheel lock type just want them black
Not sure on the size and where to get the best prices
Thanks
🇨🇦 2020 RAV4 XLE Hybrid - Super White
Thanks
Check with your dealer these part numbers:
Black lug nuts (6 pack) - PT076-60200-02
Black wheel lock DIO - PT276-35200-02
Can’t see it being more than $70
Thanks
Are you looking for Toyota OEM style or cone (for most aftermarket wheels)?
Size is M12 x 1.5.
eBay generally has good prices on Gorilla black lug nuts.
2020 Toyota RAV4 XSE Hybrid (Blizzard Pearl/Midnight Black Metallic)
2021 Hybrid XLE Premium
LP Adventure LP7 - Bronze - 17x8 +20mm offset
Cooper Discoverer AT3 4S 245/65R17
No rubbing even at full U-turn
I think the offset for these wheels is perfect for the car. Stick out about ~18mm further than stock.
I also put a set of the Cooper A/T's on, I went with the 235/65/17" same as stock O.D 29.2" and Rav4 cleaned up.jpg didn't lose any MPG at all, how is yours doing with the bigger tires , did you lose any MPG
19’ Hybrid XLE
Brand: Black Rhino
Model: Boxer
Offset: 15
Tire: Falken Wildpeak At3w 235/70/16
MPG: Seem to have lost 1-1.5mpg...not bad!
Ride: No more road noise than the OEMs, not as squishy of a ride, but still very comfortable. Does not feel sluggish with weight increase.
OEM 17” with firestone destination: 48.6lbs
New wheels: 56.8lbs
Hey Patruck,
I'm thinking of running the same tire setup with the following wheel which has a 0 offset, do you think the setup with ~1/2" more poke would cause any rub? I'm unlifted.
I'm asking you because you are running the closest set-up to what I'm looking at.
Thanks
158140
2020 Rav4 LE AWD (Super White)
158387
Got these on my winter tires. Now... what to do for the rest of the year? Everyone on this thread has been giving me lots of options to think about.
Edit: they're KMC708 Bully wheels.
New Shoes for Baby on 2020 XSEh...
-TRD Wheels PT758-03200-02 (19" x 8.5" +45mm, Hub 60.1mm, PCD 5 x114.3 mm
-TRD Centercaps PT280-03200-02
-Black Lug Nuts (6 in set) PT076-60200-02
-TPMS 4260702050
-Michelin Pilot Sport All Season 4, 245/50R19
Handling is much improved over stock 225/60R18 Dunlop Grandtrek PT20... more mechanical grip with less understeer. Very pleased. The combination of change in wheel offset, wheel width, and tire width place the outer edge of the tire in the stock location.
Interested in how the handling will change with H&R DRM TRAK+ 5065601 (25mm) wheel spacers.
Any from far away? I plan on putting these on my Prime
