461 - 480 of 513 Posts
Prime XSE Premium
Those look super. Love the clean stealth look of your ride. Details on wheels and tires:
Wheel: Make/Model/Dia/Width/Offset?
Tire: Make/Model/Size?
Thanks,
Platinum Elite 432SB Wheel 19x8.5 Satin Black 5x4.5 (5x114.3) 40mm Offset.
Tires are OEM Yokohamas, 235x55x19, you can do better
Wheels were cheap and lighter than stock. Cheap plastic center caps that I painted.
2020 RAV4 Hybrid XLE Premium
Thanks,
Well done! 👋👋👋
Brand: Motegi
Model: MR118
Offset: +45
Tires: 245/65R17 Falken Wildpeak A/T3W
Just a fair warning, +45 offset with 245/65R17 will cause slight rubbing when doing a full lock turn, otherwise it is just fine.
You posted this in 2019. Any other issues long term? This is the exact set up I’m thinking about. I found a set of these wheels for $280!
The whole set for $280? Holy moly did you find this locally or online 👀
A whole set. No tires. Its on fb marketplace. But they are +45. Its the same exact wheels as post #7. Looks like they would work with some rubbing. I messaged him asking how bad the rubbing was.
What do you guys think of these with my black Prime?
https://www.tirerack.com/wheels/WheelCloseUpServlet?target=runWheelSearch&initialPartNumber=MR14077012738B&wheelMake=MOTEGI RACING&wheelModel=MR140&wheelFinish=Black Painted&showRear=no&autoMake=Toyota&autoModel=RAV4+Prime&autoYear=2021&autoModClar=SE
I love some of the Method wheels but they are so heavy. Id probably lose quite a bit of range and performance.
My OEM SE wheels are 55 lbs. Measured them this morning. I really dont want to go heavier, Id prefer to go lower.
For a similar style I have TSW Chronos in 18”s that are rotary forged and light.
They are 33lbs each I think, made a noticeable difference in acceleration on my Subaru
I wasn’t going to run TRD Camry I’d put those on.
33 lbs is higher than I want to go. I am looking at wheels that are below 20lbs. These MR 118's are 22lbs. MR 140's look nice too and those are 17.4lbs
That is surprisingly light for the price point. Is the weight rating good for the GVWR of the Prime?
Im sorry for taking up for most of page 24 but before I pull the trigger I want to run this situation by you guys. I've never bought a new set of wheels before.
1. So I found a set of slightly used Motegi MR 118 17x8 +45 wheels. I wish they werent +45. I was hoping for a wheel that was 25-30. But the price is right. I can have them for $260 for all!
https://www.tirerack.com/wheels/Whe...h=Black+Painted&showRear=no&packageFlow=false
2. I found this site and looks like I should get 225/70R17s to correct my speedometer. OEM wheel is 225/60R18 but the speedo is constantly 2 mph high. Id like to correct that. 225/70R17s would do that but I am noticing that they arent a common tire.
225/60-R18 vs 225/70-R17 Tire Comparison - Tire Size Calculator | Tacoma World
3. I found these 225/70R17s tires on Walmart. No name brand. Any good? I want a tire good for snow and light offroading.
https://www.walmart.com/ip/Federal-Couragia-A-T-225-70R17-116-Q-Tire/699567242
Here is the list that Tirerack recommends for my car with MR118 wheels but they are all 225/65/R17
https://www.tirerack.com/tires/Tire...&skipOver=true&minLoadRating=S&wtpackage=true
I found these 225/70R17 used locally. Do you think they are good? I just asked him what model they are.
https://albany.craigslist.org/wto/d/dearing-cooper-tires/7222608834.html
4. Weight of my Prime is 4,300 and I like to be able to tow a 2200lb small camper. Issues with these wheels and tires?
Thank you!
Got fresh new wheels and tires to show off today.
Falken A/T Trails 245/65/17
Enkei Kojin 17x8 stock 40 offset
new combo weighs 57 lbs vs 52 lbs for stock XLE Premium w/ Michelins
158544
158545
158546
First thing tomorrow that strip of chrome above the window goes away!
2020 Toyota RAV4 XSE Hybrid (Blizzard Pearl/Midnight Black Metallic)
Reactions: TikiTime
Looks good! Any more pics from the side?
I was testing some 16" steelies from my other cars, and they looked very small on the car. But yours looks fine.
Wow this is the winner of the thread so far. This size looks perfect!!!
