1 - 8 of 8 Posts
Posting pictures of Unorthodox underdrive crankshaft pulley...neat piece, 2000 Neon tower strut bar modified to fit Cubby, and handbuilt $323.95 value MSD 8.5 mm spark plug wires.
The Unorthodox pulley was a pain to put on. Had to pull both undertray covers, flywheel cover, take right front wheel off, power steering bolts (not much fun) crank pulley bolt REALLY!!! tight. This is a nice part. Unorthodox even gives you the new Gates belt #. However, I did drill and tap two holes for future removal.
Son's hand-me-down 2000 Neon strut brace took a little modifying. I put extensions on inside rear bases. Drilled two new holes in each base and added a little extra diagonal bracing. The part was inexpensive originally, I think less than $20.00, and it looks cool, too.
These spark plug wires are basically handbuilt, using all the old hardware from the 5 mm wires, boring out the phenolic tubes on lathe, enlarging holes in tube boots, coil caps and seals, etc. 6 hours labor plus $83.95 equals $323.95 and a lot of b***s*** from the seller.
Great mods, good job! :thumbs_up:
It is nice to see another member here that is willing to adapt other parts from donor cars to make a mod. work. The strut tower bar and pulley look great. I too had to modify my spark plug wires when I got them because they were way too long for my RAV. My seller also told me that that is how they are made and was unwilling to take them back. I had to cut and crimp them back together to the right length. :roll:
Victor, I also edited your topic title so that it is easier for others to see that this topic is about posting pictures of your mods. :D
Looks Great. We just need your driving test opinion. Question
Like Pancake asked;
1. Is their any advance in performance?
2. How much did you torque the pulley bolts down?
3. Part, part number and cost.
4. The level of difficulty [I express it in RAV4. 1 RAV4 being easy, 5 RAV4 being very difficult]
You should document any exterior part that are adapted for the guys on the forum. That is very important. [pictures, procedure so on, if you like] This is just my opinion of doing things. It has benefited everyone in the forum. Also, you won't get a ton of Emails asking questions. Believe me they come from all over the world in many languages.
Answering mod questions
Yes there does appear to be more power, and most notable a quicker throttle response, my wife says I am almost running over people when accelerating of a stop light.
Unorthodox guarantee's 7 HP & up to 11HP.after computer normalizes.
Pully bolt torque is 140 ft lbs.
Unorthodox Rav4 96-00 pully Pt # is 02.12.101.02 I bought it through Mark1 motorsports on ebay.
Level of difficulty is about a 2, just follow the directions in a Haynes service manual, hardest part is loosening & tightening the power steering bolts, you need a handfull of misc. 9/16 or the mm equivalent open & box end wrenches and a little time.
A tower strut bar keeps unibody constructed vehicles from flexing under hard cornering, I am thinking about racing in some Autocross events later on, and the strut bar looks cool and was free so I thought I would try and make it fit. :D
http://www.mach1car.com/index.aspx :cheers:
vicco27.......Keep Rollin.
can u check to see what size of tubing is used for the strut tower brace?
As I said in the earlier post, it's an aftermarket, manufactured, hand me down, 2000 Neon strut bar that I re-did the end mounts on to hook up to the RAV4 towers. I moved the anchor points from both the tower mount and moved the strut brace mounts on the anchor plate. The tower brace to strut bar are 1/2" heim joints. The strut bar is a somewhat flattened tube 1 1/2" by about 3/4" with a slight curvature. Basically you could do the same thing with some 1" round tubing, a couple of heim joints, some plate to cut the mounts for the towers out of, and a couple of pieces of flat strap.
1 - 8 of 8 Posts
