Well, first you would have to have a Multimeter. From the sounds of it, that's unlikely.You're going to have to assist with the steps of testing with an ohm tester.
1. set your multimeter to resistance, or ohms, or the little round ohm symbol. Accuracy of your meter doesn't matter, as we're just looking for connectivity, rather than actual resistance measurementI have one but used it for other tests
I would not call it "less wiring incompatibilities" since it is fully compatible. CarTrimHome kit has harness to connect to the plug under the steering wheel, which makes it much easier to install. It does have an optional yellow wire not used for RAV4, but you can just ignore it.So is the consensus that the CarTrimHome version is easier to use since there's less wiring incompatibilities to worry about?
Alright thanks for the clarification. Guess I'll be picking up the cartrimhome version.I would not call it "less wiring incompatibilities" since it is fully compatible. CarTrimHome kit has harness to connect to the plug under the steering wheel, which makes it much easier to install. It does have an optional yellow wire not used for RAV4, but you can just ignore it.
There are much better options on aliexpress, cheaper and have more features than just folding mirrors..I would not call it "less wiring incompatibilities" since it is fully compatible. CarTrimHome kit has harness to connect to the plug under the steering wheel, which makes it much easier to install. It does have an optional yellow wire not used for RAV4, but you can just ignore it.
Mind linking me on what these options are?There are much better options on aliexpress, cheaper and have more features than just folding mirrors..
2. The meter now shows max or infinite or something - this is an open circuit, no connection. Touch the two leads together, it should jump down to around zero - that's a connection.
3. Take the cartrimhome switch, hold your two leads on each possible combination of pins, and see if they are connected or not connected with your meter.
4. repeat for all switch settings (I'm not familiar with the switch, is it just pushed and not-pushed or are there 3 settings like the oem switch?)
Helpful to note the relation of the pins you were testing vs. the color of the wires on the cartrimhome wire loom.
From all that info, we compare against posts above about the oem switch and its pin #s and colors, and come up with a map between the two.
Good luck, let us know what you find
I would have concerns too. It appears that this switch only sends signal to the controller, which in turn determines the mirror state. The instructions that come with this explain how a different number of open and close signals the operation of the mirror changes. Not sure how well this would work with the OEM armrest switch. I'm wondering if there isn't a mirror controller that Toyota has installed on cars with the folding function from the factory.Great explanation for this switch.
I’m more concern with the new switch and it’s connections
I wonder if now that the Rav4 Prime has folding mirrors with the XSE trim, J Vin XSE and Limited hybrid trims will have an easier time with the upgrade?If PIN 11 and 12 have wires, you may be able to connect the fold/unfold wires to the mirror switch easier. There are still lots of work to complete the power mirror kit installation.
The XSE Prime in the US does not have folding mirrors.I wonder if now that the Rav4 Prime has folding mirrors with the XSE trim, J Vin XSE and Limited hybrid trims will have an easier time with the upgrade?
I have glanced through this thread but at this point isn't it just the motor and switch part numbers needed from the Prime and you are good to go with a normal J Vin hybrid? No more aftermarket parts needed, correct?
Oh I see, the specs state "folding feature" they mean manual folding.The XSE Prime in the US does not have folding mirrors.
