Hi Everybody,
New user here looking for some help/advice with narrowing down the problem with engine start-up.
Background. My friend's Toyota has problems with starting and I'd like to fix the problem but I have no experience with Toyotas (did a bit of repairs on my old Ford Mondeo).
Problem. Current state is that the car cranks but will not start, except the "first" time (after some break? Cold engine?) when it will run irregularly for few seconds (3-4). There's no Check Engine light on, battery is almost new, ignition cables have been replaced and spark checked.
How it all started. I hope I remembered the story correct: I was told that some time ago (2, 3 months) someone started driving the car with a rapid jerk (how's that possible? High RPM + hand break?), since then car didn't run the same, as time passed it seemed to not get any better. At some point, after a heavy rain, the car started to have problems with startup and would run irregularly.
I went through this forum and found possible reasons that I would like to check (I just had a brief look today):
Car is Toyota RAV4 1999, gasoline, 4WD, automatic gearbox.
Any suggestions greatly appreciated.
- IAC Valve
- Skipped timing belt - how to verify?
- Problems with fuel supply - fuel pump (power supply, relays, etc.), proper pressure
- Grounding problem
- Clogged EGR
- EFI relay
- Fuel safety switch (is there one?)
- Disconnect battery, wait, reconnect?
