1 - 2 of 2 Posts
2015 Ltd. Is there a way to turn the engine off and have it stay in ACC mode?
I'll be driving it and get to where I want to be but want to park and continue to listen to a radio program and forget I'm not in my Tacoma and hit the button.
Hit the button again and gets me back to ACC mode but have that annoying delay with the disclaimer screen.
Is this possible or just live with it?
Discussion Starter · #2 ·
Did a little more digging in the manual and found this and my wife verified it worked though I have yet to try it myself.
If the engine is stopped with the shift lever in a position other than P,
the engine switch will not be turned off but instead be turned to ACCESSORY mode.
Perform the following procedure to turn the switch off:
Check that the parking brake is set.
Shift the shift lever to P.
Check that the smart key system indicator light (green) flashes slowly and then press the engine switch once.
Check that the smart key system indicator light (green) is off.
1 - 2 of 2 Posts
