I managed to do a Qi compatible wireless charger under the head unit area.
Parts needed:
1. Single coil wireless charging kit http://pages.ebay.com/link/?nav=item.view&id=311548764828&alt=web
2. Micro usb hardwire http://pages.ebay.com/link/?nav=item.view&id=272053996012&alt=web
3. Blade fuse tap http://pages.ebay.com/link/?nav=item.view&id=131089523065&alt=web
Installation:
1. Remove top rubber and plastic cover. (See pic 1)
2. Center align the single coil wireless charger then gently fold the board under the coil. (See pic 3)
3. Tape it in place with electrical tape of thin clear tape.
4. Do a test before putting it back in the car.
5. Run the hardwire under the dashboard. The side panel by the passenger side is flexible enough to push the head of the micro usb in the opening.
6. If needed or if your micro usb head is thick, try to trim it out as safely as possible without damaging or exposing the wires inside.
7. Using the blade fuse tap. Tap into the fuse box under the dash board. You probably won't be able to use the cover once the tap is done, just put it in the glove box compartment. Make sure ground is also connected. (I tap it to the cig 15A fuse location)
8. Attach the micro usb to the single coil wireless charger.
9. Align the platform then gently press it in place. Do not press do hard cause you might damage the charging board.
10. With the engine on place your Qi compatible wireless charging phone and your phone should detect the wireless charging. If not make sure the coil in the center of the plastic cover.
See pictures for references.
Parts needed:
Installation:
