1 - 2 of 2 Posts
I just bough a 2010 Base and am super excited.
I am looking for a place to wire my dashcam and ran in to a bit of a problem.
The label on the outside of my fusebox does not match the pages in the manual.
I am a little confused about what fuse to tap. My original idea was to use the heated seat fuse or the moonroof because they are not installed in my car.
You can get dash cams that plugs into the 12v accessory socket. This way it is only on when the car is running plus no figuring out which wires to splice.
You can also wire the power to a 12 volt socket connector if you have the web cam without one like this:
12V 24V Male Car Cigarette Lighter Socket Plug Connector on Off Switch 1 5M LS | eBay
By the way there are 2 more fuse boxes that are located in the engine area so maybe you are looking at the wrong one in the manual.
1 - 2 of 2 Posts
