i am interested to switch my 2006 base to a 2016 XLE
i have found that there is only 1 projector for both low beam and high beam.
just wondering how that work, is that switch on the light bulb or that is mechanical inside the head light??
It's a 2 element HIR2 bulb. Like old days bulb. Also lights up on lower voltage as DRL.
the reason i ask this question is because i think the 2016 use 9012 bulb and it seems like there is only 1 filament inside the bulb...
You're right. Probably uses a damper in the projector for hi-lo as in HID's.
