It appears I have a bad contact on my map/dome light assembly. The drivers side does not work, but the passenger side is fine. The bulb is not blown so I assume its a bad contact. I switched the bulbs just to make sure.
Has anyone ever removed this? There are two screws under the lens. I assume if I move them the whole assembly will come out, but before I break something I thought I would see if anyone here ever took one out and if there are any additional clips?
Thanks in advance
Thanks in advance
