After doing the rack bushings I am now getting an intermittent VSC/Check Engine light. It cuts my power to the throttle for a short time. Then, after you sit and wait a while, you can drive normally with the VSC/Check Engine light. The CE codes are for Throttle Position Switch. Reader doesn't read VSC codes.
What is strange is after the car is derivable with the VSC/CE lights on, the lights can be reset/cleared by arming and unarming the car alarm. Thinking there was a problem with alarm (there is a wire that looks to be pinched off from the splice on the wiring harness under steering wheel. That wire can short if touched to ground) I unplugged the wires to the alarm. This did not help, the problem still happens but I can clear the VSC/CE lights as the alarm is not working.
I am guessing that the VSC needs to be reset. To take the rack out you have to unbolt the sway bar. With the sway bar loose and moved around when removing bolts and rack, that must of did something to the VSC. Not sure why it would trigger the CE light and why the throttle is disabled? I will try and see if I can reset the VSC with a jumper wire on the OBD2 port.
