Have a 1999 Toyota Rav4. Stock radio, cigarette lighter, and the clock all do not work. ALL FUSES ARE GOOD. Please advise
If the rear power outlet is dead also, then check the ACC Relay.
The fuses you checked inside the car is where you find the Acc relay, it is one of the 4 relays on the backside of that fuse panel.
Assuming that both the cigarette lighter and clock stopped working at the same time, then the only things in common would also cause the remote control mirrors, radio, and shift interlock to also fail.
If you do not have problems with these additional items, the the lighter and clock are probably failed for different reasons. Have you probed the lighter socket with a voltmeter to confirm if 12volts is present? You may just have a defective heating element in the lighter.
