G
To remove the radio, start by prying off the two trim pieces(left+right) next to the radio. Use a thin screwdriver(wrap it in tape) and wedge it in the bottom, in the innermost corner (.2 inch flat spot, closest towards the radio). Just pry it slowly and it should pop out. Then the head unit is held by four(4) ten mm bolts. You will need a magnetized 10mm socket on an long extension so you won't lose the bolt while loosening.
Thanks for this! :D I gave it a shot and it wasn't that difficult. One step closer to re-doing my XM receiver. :) Still need a couple more things. One is a bracket to hold the SkyFi. The other is where to get power.
Do you happen to have a wiring diagram?
