I have this ABS light popping up occasionally. It happens more often. When car starts – all clear, 10-20 min later light is on. I checked each ABS sensor, pulled it out and cleaned them but didn't help. I also connected OBD2 scanner Maxiscan MS509 but when light came up there wasn't any error code. I suspect ABS module is playing up. Any other ideas?
Reactions: HiTorque
The codes will tell you which one. BTDT.
I just read the codes and they were:
ABS: 49 - switch activated by brake pedal
4WD: 48 - ???
P/S: 41 - ???
I reset them all as per your reference and so far so good. I cleaned the contacts of the brake pedal switch.
What are those two errors? I can only guess this was something in the past before I bought this car and Toyota techs didn't clear the codes.
