Hi,
Rav4 2009 Sport I4 here, 143K km.
I had to replace the front right suspension arm back in April this year. Today, I'm told that I need to replace both the one that was new plus the one in the right, after noticing that my steering wheel shakes when breaking.
Is this a common issue on these vehicles? I'm getting concerned that this becomes a money pit.
Thanks.
Have you replaced the rotors and pads? My '06 shook pretty bad when I bought it used last year, so I got my rotors turned. 10k miles later, same problem returned at higher speeds, so I completely replaced the front brake rotors and pads, which cost me $200 to have put on. Problem is gone again. BUT, I have been noticing that I also get some extra noise in the front suspension with rough roads and I think its a faulty strut mount. I'm really hoping the suspension isn't causing the rotors to warp (which can be a culprit), but if I have more shuddering problems in the next year or so, replacing suspension parts is my next step...
No, I haven't, although they (the rotors and pads) are in pretty good shape according to the guy at the garage.
Hmm... On slower stops, do you still feel the brakes catch and let go? That was a sure sign my rotors were warped, and I also got the "Your rotors and pads look good" from the mechanic that replaced my alternator. I'd definitely get a second opinion before shelling out all the money for new control arms.
No, I don't. Today the guy replaced one of the arms and the shake-when-breaking thing is kinda gone. The guy says the other arm has to be replaced as well, but I'm going to follow your advise and get a second opinion.. it'd be 500$ down the tube this time around.
Thanks!
