1 - 2 of 2 Posts
Does anyone know the correct torque settings for the caliper slide pins and caliper bracket bolts for a Rav4.3 v6 2010? Rear and front wheels.
I found some information on other threads. Unfortunately they were not specific to the V6...
Thanks
This is copied and pasted from the service manual:
9. INSTALL FRONT DISC BRAKE CYLINDER MOUNTING
(a) Install the cylinder mounting with the 2 bolts.
Torque: 98 N*m (999 kgf*cm, 72 ft.*lbf)
(b) Install the cylinder with the 2 bolts.
Torque: 34.3 N*m (350 kgf*cm, 25 ft.*lbf)
11. INSTALL REAR DISC BRAKE CYLINDER MOUNTING
Torque: 88 N*m (897 kgf*cm, 65 ft.*lbf)
Torque: 26.5 N*m (270 kgf*cm, 20 ft.*lbf)
And yes, the torque specs are the same for the V6 and I4.
1 - 2 of 2 Posts
