Perhaps the Autozone battery test wasn't accurate, or was not thorough enough to detect any actual problem. The problem as described appears to be a bad battery. Another less likely cause may be a loose, dirty, or corroded connection at the battery, ground, or starter solenoid. How old is the battery, and what brand is it?
