G
Hi all,
Going through my manual I see it indicates lift points. However, I'm uncertain as to exactly where they are and don't want to damage the car if I have to change a tyre.
Is there any chance anyone with a digital camera could take a couple of pics of the front and rear jack opints on a 97 RAV4.
If you can, it would be very much appreciated!!!
Cheers,
Steve.
Frame on the front, (that part that attaches all the stuff from the suspension to the rest of the vehicle) and the lower suspension on the rear with that little "tab" that sticks off it (pointing straight down).
Not difficult. The jacking instructions are pretty clear with the '01 and the points are the same.
Good luck. M.
Re: Thanks
OXFORDBEE said:
Thanks all for taking the time to reply.
Things are a little clearer now!
You can save a little time by using the center rail on the front to jack it up in the middle and do both tires at once. In the back though the OEM jack is too short to lift both at once, you do have to use the arm on the suspension for each side. With a floor jack you can just put it under the rear differential.
If you do lift both sides at once don't forget SAFETY!
USE JACK STANDS! We wouldn't want anyone here to be hurt.
Later. M.
