1 - 8 of 8 Posts
My rear bump stops have fallen of my rav4 and ive searched google to find out where i can purchase sum and also wer they wer located b4 thy fell off but having no luck. Its not the bump stops on the suspension its the one tht stop the axle hitting the chasis. Can anyone shed sum light on my problem. Much apprecaited if u can :)
This was posted in the wrong area and moved. First off, what year car is it? Once that is established it can be moved again to the correct area. No mind readers here friend, give us some information please in order to help you.
They bolt to the chassis tub inside the coil spring. Peek inside the threaded holes to make sure the bolt isn't snapped off in there. You can buy generic or Toyota oem, they're about the same price. You'll get some pretty impressive bangs from the rear end without them.
For a UK 1998 4WD Rav, I got these results:
BUMPER, REAR SPRING
48306-42010 W(235/60R16 TIRE) € 30.12
48306-42020 (04/1995 - 08/1997) € 30.46
48306-42040 (09/1997 - ) € 28.80
So, you should order two "48306-42040" if your Rav sits on steel wheels with 215/70-16 tire dimension,
or two "48306-42010" if your Rav sits on alloy wheels with 235/60-16 tire dimension (even though to be honest, I can't imagine why that differentiation is important).
1 - 8 of 8 Posts
