RAV4 test turf a road too far
The Age
Wednesday February 8 2006
Extreme conditions put the heat on the new RAV4's off-road credentials, writes ANDREW HEASLEY.
It must have seemed like a good idea at the time for Toyota to launch its new-generation RAV4 off-roader in the rugged Australian bush; a chance to show that a city-slicker compact soft-roader can cut it in the wild.
But a combination of 45-degree heat and harsh terrain in South Australia's Wilpena Pound made for a formidable challenge that saw the RAV4 struggle and had Toyota engineers - flown in from Japan - scratching their heads.
The new RAV4, which will make its Australian debut at the Melbourne motor show this week, has gone from a constant four-wheel-drive to a torque-on-demand system, with a maximum of 45 per cent of the engine's torque fed to the rear wheels when needed.
It has also gained a lot of weight - 140 kilograms - over the model it supersedes (now 1550 kg to 1590 kg), yet the engine has been tweaked to produce just 5 kW more, 125 kW at a lofty 6000 rpm, and 224 Nm at a rather high 4000 rpm. The weight blunts acceleration.
The RAV4 struggled to climb a steep gravel incline from a standing start. Twice, the manual car simply washed off engine revs until it stalled, and out of fear of burning out the clutch, the decision was made to abandon the exercise, reverse down and take a run-up to the hill, which was successful.
A water crossing that followed posed little challenge for our car, but other Australian media complained trick electronics (it was presumed) limited the cars' power, leaving barely enough to create a wake ahead of the front wheels.
The following day, the engineers went back to try to replicate the scenarios, but were unable to repeat the problems. Investigations are continuing, Toyota says, with the extreme heat a possible factor.
"These were the same roads we launched the LandCruiser 100 on," said Toyota Australia executive chairman John Conomos. "We wanted to show that the RAV4 could handle these roads if somebody wanted to, but we've taken it to the extreme."
All cars made it through relatively unscathed, except for a couple of punctures and some underbody plastic cladding that pulled away.
But Mr Conomos says hard-core off-roading is not the car's typical operating environment.
Toyota is pitching the bigger RAV4 to an older clientele than the previous car, to young families as an alternative to conventional station wagons and to empty nesters.
The car is bigger in all dimensions than its predecessor - that 140 kg weight gain has gone into a body that's now 170 mm longer in the wheelbase, with 130 mm more interior length and a bigger cargo area at 540 litres. Inside, Toyota says it has 20 per cent more space and 35 per cent more cargo volume.
Plenty of thought has gone into the flexible interior. The rear seats have a fore-aft individual sliding mechanism and the backrest is tilt-adjustable. The seats fold flat for a level cargo bay, and there's a 90-litre well under the floor that would be handy for sandy or wet items.
As the car has grown, so too has the price. The range starts at $31,990 for a base five-speed manual (right in the thick of the action) but now stretches to $41,990, with autos $2000 more - approaching Ford Territory territory.
This time, there is one five-door body shell, with no three-door variant.
The RAV4 has three trim levels: the base model is designated CV, the mid-spec Cruiser and the top line Cruiser L.
On our brief encounter, the auto seems a better match for the engine, masking the torque deficit under 2000 rpm.
Despite the extra load, the engine has improved fuel consumption: 9.1 litres/100 km for the manual, 9.6 for the auto.
The new RAV4 comes with a raft of electronic handling aids, including stability and traction control (Cruiser and Cruiser L), hill-start assist and downhill assist (autos only). There's a push-button 4WD "lock" system to engage full-time 4WD at speeds up to 40 km/h. There's electric power steering, ABS brakes with electronic brakeforce distribution and brake assist, and six airbags in the middle and top-spec cars, two in the base CV, though there's a $750 safety pack (side and curtain airbags) offered.
Creature comforts include air-conditioning, cruise control, telescopic tilt-steering adjustment, six-CD MP3 audio as standard on the CV, dual climate control in the Cruiser and a leather interior with powered driver's seat, heated front seats and a moon roof in the Cruiser L.
Mr Conomos says the new RAV4 is expected to regain leadership in the compact sport utility vehicle segment, with projected sales targets of 1200 to 1300 a month, depending on supply.
Prices and details correct at publication.
A V6 would have made it up the hill, even the TD would have with all its torque. This is not a good PR start for the Aussie 4.3 before its even oficially released!
I found the Auto very capable off-road. Turbo diesel would be better though, your right.
M.
