1 - 10 of 10 Posts
W
i just want to ask if what is the best offset of mags that would fit a oem flared rav4 5 door 97 model
im thinking of getting 18's with 235 55 tires ,would this fit?
is there anyplace here in osaka that still sells rav4 4.1 accesories like exhuast ? and jaos rear plate as well thanks
thanks
I replaced my 215/70/16 original wheels and tyres with 235/50/18 wheels and tyres. The offset of the original wheels was +45. The new wheels have an offset of +36 so they stuck out past the guards. This only happened on the front and not the rear. Reason being theres more space in the rear wheel wells and the wheels also sit at more of a negative camber than the fronts do (you can see this in the pic below).
Because the front wheels were sticking out i got some OEM Toyota overfender flares which fixed the problem and make the car look much better. If you already have flares then go for an offset or around +35.
W
thanks for the pics, it gave me an idea, is 55 series not possible with the 235 18?
W
ic thanks alot , coz i think 50 series in our country is not so good.
235 55 18 were fitted in gen 2 rav so is it possible to fit in gen 1 ?
thanks
235 55 18 is so close to the stock size you shouldn't have any problem fitting them.
For comparisons... we have a RAV4 Tire Fit List in our LINKS section. Use the "Tire Size Calculator" mentioned in the first paragraph on that page 8)
W
Discussion Starter #7
17s or 18s
thanks alot sir, im still thinking of what rims to put, whether 17's or 18's, friend suggested me to just put 17s because 18's isnt that safe in the roads, but i think 17s are too small to look at in a rav what do you guys think ?
the rims if 17s is going to be bronze ce28 by volk, :D
Re: 17s or 18s
If you get the 17s, it'll make your wheel-gap bigger. In addition to lowering my suspension 2", I got 18s. I was gonna get the Volks TE37s in gun-metal gray, but decided to get something else from Ray's Wheels. The CE28 is nice!
1 - 10 of 10 Posts
