sooperedd said:
I want to get that bumper protector, but I have a couple of questions.
1.Is the bumper protector a long piece of hard plastic or is it like a sheet of plastic?
2. Does it cover the one that came with the RAV or do you need to take the old one off?
3. It looks like it screws on, is that correct?
4. Any problems?
Thanks to all !!
1. Its preformed, rigid and pretty sturdy once installed
2. Yes it covers the stock, no need to peel off the stocker
3. It uses the current clips that hold the factory one down, just carefully pull up the middle of the clip and pull it out of its hole.
4. Not if you take your time to install. Clean the bumber, peel the tape off, carefully line up the holes to match the bumper before letting the guard touch the paint and then press it evenly down (I sat on the guard in a few spots to make sure all the mounting tape had made contact with the bumper).
Get it, use your rear gate without worrying about scratching the paint, be happy.
