Hey, can anyone give me clear instructions on how to remove the rear bumpers on the rav? the bumper extensions that has the reflectors in them.. thanks
Looking at the diagram.
Open the door and exposed is 2 bolts on the side which should come out horizontal towards center.
1 bolt opposite Pointy corner (wheel well). Bolt is tucked in. It comes straight down
1 bolt is behind the reflector but i believe it just holds the Reflector on so do it last if you must.
Good Luck,
Walt
where can i locate the diagram at? thanks
ahhh, i've gotten it. there were 2 bolts, 3 screws and a clip i had to evade.
Here are pics showing the locations of the various fasteners. You'll need a phillips head driver and a 10mm socket on an extension drive. The snap clip on the underside of the rear top part of the bumper corner cover is a bit grabby - persevere, but don't 'snatch' it off.
bit of a late reply to this thread, but any tips on how to remove these fasteners ie tools etc. it looks like they're hinged from the inside of the hole as well so not sure how it pulls out.
