1 - 11 of 11 Posts
Hi,
My first post is unfortunately a negative one. I found these dents on the rear bumper - looks like I was hit in a parking lot. This bumper was just replaced about a month ago. Is there a DIY fix I can do or would you recommend not risking it and/or go into the shop? The material of the bumper has me thrown off on what can be done at home.
Thank you!
Looks like the damage I had to a rear bumper when someone who had projecting acorn-shaped mounting nuts on their front licence plate bumped into my vehicle. The nuts left the same type of indentations on my rear bumper. They were too deep for me to pop out with a hair dryer, for example, so I had to have a body shop replace the bumper cover. Fortunately the guilty party paid the bill so I could keep it off my insurance.
Ahh, bummer. Sorry it happened to you as well. Thank you!
Hi,
Thank you!
Yep, I'm sorry that you had this happen as well - extremely annoying! Maybe the cover can be removed and the indentations pressed out, but there probably would still be remnant signs. Of course that won't work if the cover has been penetrated or the indentations have crack marks inside of them. Good luck, and hopefully you won't have to have the bumper cover replaced yet again!
Reactions: SarahM
I don't think it's DIY fix,especially the left one. They are too small to replace whole bumper and if you try to fix it by yourself could make it even worse.
You could try Plasti-Dip spray-on coating (or similar brands of rubber coating) to cover the entire rear bumper. It's rubber based and will hide those holes as well as provide added protection to your bumper. It's much cheaper than replacing the entire bumper. It can also be applied professionally.
Reactions: SarahM
that's the reason I leave my hitch ball on ... nothing you can really do, the plastic is stretched and will not go back to the original shape, you can try filling it, and plasti dipping it but even that will not last more than a year or two...
Reactions: SarahM
Thank you, again! Hoping for that too... but not banking on it. :crying
Discussion Starter · #9 ·
Ack. So just have to suck it up for the time being, it seems?
Discussion Starter · #10 ·
Thank you for this idea! Will check it out.
1 - 11 of 11 Posts
