Looking for part number for the center rear door hinge on a 2010 base. When the door swings open, the hinge (or something stuck in it?) makes a popping noise....twice. Pic included, it definitely appears damaged.
Not having much luck with parts diagrams and my assumption is that the dealer will want both an arm and a leg for the part, so trying to source it through a third party.
In advance, I appreciate the help!
There are only 2 hinges, upper and lower. That thing in the middle is called a "check strap" and keeps the door from opening too far. Officially Toyota calls it the Back Door Check Assy--the part number is 68650-42071. Google that number and you will find many online dealers selling it for around $78.
Ouch! on the price for the check strap. Maybe try a salvage yard . . .
looks to be plastic around the metal part...maybe cutting the plastic away will get rid of the noise til you can replace the assembly...
