Hi, I am looking for some info re placing of clips for the trim on the rear door above the back bumper There are basically 3 types of clips. One type which goes top-middle of trim, then a second type (2-clips) which I am still figuring out where the fit, then various clips (the third type) which fit everywhere else. Any diagram maybe? Thanks
Since your car does not appear to be made in NA it is slightly different then ours. All the clips are exactly the same for our models. You should be able to remove the panel starting with the trims along the cargo window. Using a trim removal tool should make it easier. The rest of the panel can then be pulled out. The center clip maybe the hardest to remove so just pull with even pressure and take your time. Once you have the panel off you will see the holes where the clips attach to.
