1 - 20 of 543 Posts
Hi all,
I just bought a new 2019 Adventure trim and I'm wondering if anyone else with AWD with the Rear Driveline Disconnect feature has noticed a slight "clunk" noise when braking, right around 19-20MPH.
I'm thinking it is the driveline disconnect re-engaging the rear wheels, because when I set the gauge cluster display to show the engagement and torque vectoring of the AWD system, the noise correlates to when the driveline is engaged and re-engaged on the display. When I put the car in sport mode, which forces AWD all the time, the noise does not happen on deceleration/braking.
It mostly happens during deceleration/braking, but only occasionally during acceleration, right as the display indicates power has been cut from the rear wheels (as I've gotten up to speed).
I took it to a Toyota dealership but the Techs there acted like it was a spaceship that they had never seen before since it is so new, and had no idea it even had rear driveline disconnect, or what that even was. They said it didn't sound "bad" but admitted they heard the noise too.
At the end of the day, I guess I'm asking "Does anyone else's Adventure or Limited with the AWD make a slight clunk noise when braking around 19-20 mph?"
Hi all,
Mine does. It's 2019 rav4 limited. I just noticed this couple days ago. When the odo reached 1000 km. I didn't notice it before.
I have a 2019 Adventure with about 1,800 miles on it. I listened closely for a noise when it was new as it seems like it should be noticeable when it engages. I wasn't able to detect anything. There is so much snow now & the roads are so bumpy that I don't know if I could tell if something developed in the last 1,000 miles or so. With regards to Sport mode - I am pretty sure it still disconnects under low-load conditions. I'll have to double check.
I'm really liking the vehicle, although the current tires (Toyo) don't have the greatest traction. My wife got stuck in a spot that she didn't think she should have. She was disappointed that the Rav4 didn't perform as well as a Kia Sorento with studded snow tires that happened to be there also. It was in a remote area - luckily there was someone to push her out. It will definitely be getting Snow Tires next year & possibly new wheels also. I suspect that will make a huge difference.
I tried to hear the disconnect noise but haven't heard it yet. Lots of snow here so the tires are a bit noisy on it. But now knowing the speed, I'll try to look out for it on the drive home. Just look for the rear axle highlight to go away?
The Toyos are ok when driving slow, but I had to get winters tires because they simply could not corner or stop once the roads got iced over. I downgraded to a 17inch wheels/tires and they made a HUGE difference. The Toyos were decent on snow which was surprising. Hopefully they make a good summer tire.
Everyone please watch out for this. While driving tonight the clunk has turned into a clunk coupled with a grinding noise when accellerating when the rear driveline disconnects. I have it scheduled to take to dealership. Will update.
With regards to what to look for, yes, look for the rear drive axle to go dark when accellerating, unfortunately I hear the clunk greater when slowing, but if you take your foot off the accelerator and apply the brake, everything on the AWD display goes dark. I've narrowed it down because if I hit the gas right after I hear the clunk while braking, all wheels light up on the display as getting power. If I brake and hit the acellerator before I hear the clunk, it still only shows the front as lit up and engaged. That's whats leading me to think the clunk is that driveline disconnect mechanism.
I'm no mechanic and I don't have the new transmission(have XLE Premium), but we used to have a clunk issue with our 13 4runner. The driveshaft was 2 piece design and it would contract and expand as needed. Sometimes it'd stick and clunk when accelerating off the line and we never got a reason, repair or good explanation from Toyota about it. It periodically was so strong it felt like someone tapped the rear of the truck.
The '19 Rav4 DTV is FWD biased and isn't anything like a '13 4Runner which was RWD biased. Here's Toyota's description and graphic of how DTV works.
https://newsroom.toyota.co.jp/en/powertrain2018/4wd/
FWIW, I'm hoping these sounds are normal and not problematic of the new DTV system, I wanted a Limited trim to begin with, would have gone with a Limited HV had it been available, I had the option to get a Limited gas model if I waited a week, but I am apprehensive of the DTV system since it's entirely new for the Rav4, so I chose to go with the XLE Premium which has all of the nice features I wanted in the Limited, sans the DTV and its possible problems.
From the link: (DTV) " features the world's first ratchet-type dog clutches"
That concerned me the first time I read it. I'm sold on Toyota quality, but "worlds first" can also mean not ready for prime time.
Can anyone verify that the 2019 Rav4 non-DTV AWD system is functionally the same as the 2018 models? Tried and true, proven over time, at least reliable if not bulletproof.
I've looked under two non-DTV 2019s and the mechanics looked the same as my '06 with an electro-coupler mounted on the front of the rear differential. I'm sure the 4WD ECUs are different but the driveshaft runs full time on all '06-'19 models.
I think the non-DTV system is mechanically the same or real similar to the 4.3 and 4.4 systems, but the ability of the system to brake and eliminate wheel spin on a wheel with no traction and send the power to the opposite side thru the open diffs to provide traction where it can be used is superior, see my report, I did the same test on the same bank with my '06 and '15 Rav4s, neither made it up the bank, the right front and left rear wheels would just spin helplessly forever, but the '19 XLE Premium made it up, the multi-terrain select system put the brakes on the spinning wheels and it went right up the bank.
https://www.rav4world.com/forums/197-4-5-general/295953-multi-terrain-select-rock-dirt-test.html#post2672525
That's definitely good news. And it looks like all 2019 non-DTV AWD models have the terrain selectors so they should all do similarly well, correct? From my FJ experience I know too that tires make a huge difference. Mine was so helpless in snow and mud that I replaced the OEM tires with Terra Grapplers after 8 months. Life was good after that.
I suppose if I really wanted to tow with a (non-Adventure) Rav4, the aftermarket could supply anything necessary. I'm sure others have done so with previous years.
Yes, all gas models have Multi-Terrain Select, LE, XLE and XLE Premium have buttons, Adventure and Limited have a rotary knob, plus a DAC button. HVs only have a Trail mode button.
I’ve listened closely the last few days and it has been silent. I tried multiple modes. Nothing. I think OP has a serious problem.
Sent from my iPad using Tapatalk
Good work guys on this topic. This is exactly what forums are for.
Does anybody know if the Hybrid also have the ratchet-type dog clutch system?
Or something completely different.
Sent from my SM-G935W8 using Tapatalk
1 - 20 of 543 Posts
