Does anyone have info or instructions on how ot remove the rear inside panels to access the tailight wiring? Also how to remove the inside panel of the rear door?
Thanks
S
rear door panel just pulls off. just a bunch of fast clips. and one wire where the light is. haven't had the others off yet.
S
GENTLY at the bottom and work your way up. the bottom section underlaps the lighter pieces up top.
I would like to use theft resistant bolts in the bottom holes of the rear license plate.
Does removing the rear door panel give access to put nuts on the license plate bolts?
