Update:
I was able to pry out the old mount with a breaker bar and some elbow grease. I definitely did a number on the old mount. The bolt became slightly dislodged from the mount itself, and the bolt was bent 15 degrees when I was finished with it. The problem is that the new mount won't go in unless I find a similar way to bend the bolt, which isn't preferred. Rather, I'll be going the nuclear route and cutting off most of the front bolt such that the mount can swing in under the axle (hopefully). I'm in high hopes that I may be able to get this thing in without having to drop the subframe to finish the job.
