1 - 2 of 2 Posts
I was checking the condition of my rear Sway Bar Links and noticed that the left rear shock is getting beating. What could cause that? I may add that the boots on the left rear Sway bar links are also shot and need to be replaced. Also, the rear left wheel bearing was just replaced. Could driving on the bad wheel bearing or a bad link for some time could cause that? . Thanks
The dust cover is rubbing against the shock. You can see from the picture that it's off-center. No big deal, shoot some spray paint on the shock. You may be able to twist the cover so it doesn't rub.
1 - 2 of 2 Posts
