R
Recently did some serious offroading... Have noticed that my rear wheels appear to be out of alignment. Not sure if the camber on the rear wheels need to be readjusted. Does anyone have any advice, or have had a similar problem???
The rear wheels have a slight negative camber, which means they lean inwards a little bit. It is normal, and helps improve handling. If you think the alignment may be off a little, take it into the shop. If someone tells you the rear wheels cannot be adjusted, they don't know what they're talking about, because there are adjustment cams.
