Hello all,
I'm not sure if this has been covered but I couldn't find anything on this problem so I thoughti would ask. I have a 2004 rav4 4wd manual transmission. I recently was unfortunate enough to have to change the clutch which as a side note can in fact be changed without pulling the motor. At any rate after pulling the transmission, changing the clutch and reinstalling everything, I bled the hydraulic system and took her out for a spin. Everything was going well until about 3 miles from the house there was a loud "thunk" from the rear end and both back tires locked causing the car to come to a screeching spinning stop. I tried to go forward and to reverse but it would do neither. After sitting for about 5 minutes or so suddenly it would drive again and I limped it home. I spent the next day in its entirety bleeding the brakes with a mityvac and when I took the car for a spin it drove just fine. That was a week ago, fast forward to today when I was on my way to work and at about 60mph I heard the sound again and let off the gas pedal. I could feel definite drag and was quickly decelerating so I pulled off the road. As it would turn out I came to rest on a patch of dirt and as such was able to see that this time instead of both tires locking on the right rear locked. Again I sat for a while and when it unlocked I was able to limp it to work. My question is what could be causing this issue? I had assumed that air had made it into the hydraulics as the clutch shares a master cylinder with the brakes but now I'm not sure what it can be. It does seem like the issue is less severe than it was the first time but I have no clue as to where to go from here. Any insight or help would be most appreciated. Thanks
Discussion Starter · #2 ·
A quick update on the RAV while test driving the car, it locked up again and I have come to the conclusion that it is definitely the rear differential.
Any update? Mine just did this at 60mph. I'm dropping the rear end now.
His last post was in April 2016 so I doubt we'll get a resolution.
