Hi I've got some rust just above the rear wiper mounting stud. The rust continues up to the rear window seal. I want to sand and apply auto filler to the affected areas which means removing the seal and or window . Is there a how to or best way to remove the rear seal so that I can access the rust areas better? I'm hesitant to attempt removing the seal in case I crack the window.
