Recall for windshield wiper joint moisture issue. I had it done. With he hood up today I took a snapshot. The modification is quite extensive. (Did I shoot if from the wrong angle? From the left the vents are clearly very different. Let me know.)
Good to know pico.
Is the wiper shield - that formed black plastic under wipers arms, and between the fenders ?
On our Canadian 2008 RAV4, I have watched the wiper joints rust some.
- so I spray the wiper joints, with Fluid Film
Our Limited has electric heating element, in the bottom of the windshield.
- this largely helps to keep ice from forming on the wiper blades / I only use Bosch Icons blades
The second thing I like / morning snow buildup under wipers, is easy to brush out.
^^ Will the new Wiper Shield, be just as good as the old...in terms of cleaning out snow ?
First I've heard of this.
Good to know pico.
Yes, it is the whole tray you see between the fenders. Snow accumulation is easier to remove than the original setup because less snow gets in there. I'm impressed by the build quality.
