1 - 20 of 29 Posts
Hi, I'm looking for advice on the best receiver hitch for a 16 Rav4 Hybrid Limited. Any info on ground clearance, ease of install and appearance would be great. Thanks.
I use the Curt 2" hitch from my previous Rav4, only use it once in a while, so I just install it when I need it, I don't feel I need to carry around that extra 40 some pounds of extra weight full time, and the Curt has more capacity than the Rav4 is capable of, so no need for the Ecohitch..... and the Curt is truly hidden when it's not installed! :D
I just purchased a Reese hitch today for my RAV4 from Amazon. Reese Towpower 97234 Class III Custom-Fit Hitch with 2" Square Receiver opening. $112.00
Well I guess the install is pretty easy then. 8) Thanks. I didn't really follow the part on the cutting. Is that cutting the rear valance for fitment of the hitch or was that a cover associated with transitioning the wiring to the exterior?
I'm very interested to know how you like the Reese.
Cutting of the rear valance is required for the Ecohitch, not the others. There's also a cover on the driver's side that needs to be removed or modified by trimming to install any hitch (see reply #30 in the link), I modified it on the 2015, others just leave it off.
I have not installed it yet, but I don't think you have to cut anything. It bolts on with 4 bolts and the receiver is below the rear trim. I just saw the previous post. Sorry, mine is not a hybrid.
Discussion Starter · #9 ·
Amazon is giving me an error message that the Reese will not fit my 16 Rav4 hybrid limited. All the hitches seemed to fit both hybrid and gas models.
This is the Hybrid forum, but all 2016s need to have the rear valance cut for clearance of the receiver tube to install the Ecohitch due to the " faux skid plate", not so for the other hitches as I stated. The 2015 and 2016 have the plastic cover that needs to be removed or trimmed to install any hitch.
Amazon isn't real quick to update their database unfortunately, if it fits a 2015, it will fit the 2016.
HI Quickdtoo, do you have any pics of a hitch installed? I wouldn't mind seeing what you are referring to as the plastic cover that needs to be removed or trimmed.
I don't have the Ecohitch as I stated before.
Cape Cod, where are you located?
I just picked up a new 2016 RAV4 from Falmouth Toyota, and am looking at the CURT 2" receiver, or the REESE. Falmouth Toyota has an XLE on display in the show room with the CURT one installed, and a bike rack on it, if you want to look at it in person to see how it looks.
I did a bunch of research online, and although these aren't the "highest" of the choices, but they are well above the vehicle's clearance, and at the best price point in my opinion.
Discussion Starter · #19 ·
Hey Waldo, I'm in Sandwich. We got my wife's car at Falmouth Toyota. I just ordered a Curt hitch at amazon. It should be here friday. I have a set of ramps and air tools. Install sounds easy.
1 - 20 of 29 Posts
