Slightly crooked is a bad thing. If you can see something caught in the track, remove it if you can. I would take it to the dealer.
But first, try setting it to its default position by reprogramming the actuator. (From the repair manual.)
1. Switch ON the ignition(IG) by pressing the START/STOP button twice or turn the engine key
to IG position
2. Push and hold the TILT UP switch until the moon roof reaches the full tilt up position, then
release the switch.
3. Push and hold the TILT UP switch again. After approximately 10 seconds, moon roof will begin
the initialization procedure. DO NOT release the switch until the procedure is complete. The
moon roof will tilt down, slide open, slide close and stop at the fully closed
